Screw protruding from bathroom sink cabinet
Old 02-23-20, 01:35 PM
T
Received 9 Upvotes on 7 Posts
Hello guys. Spent lots of time under bathroom sink trying to reconnect pipes and "speed" drain connect. But body weight against hinge for extended period of time and hinge came loose. Originally screw wasn't working. So decided to get longer screw. But, alas, screw was too long and jutted out from side of cabinet. This video shows issue:
https://youtu.be/JU0Tw2_MViw
How can I beautify this and make it safer w/o too much time and effort? Do not want to reinstall hinge. Could I somehow shave the protruding screw end off and paint over it? Any easy and inexpensive suggestions would be great. Don't want to overthink/overdo this job.
Old 02-23-20, 01:53 PM
P
Received 2,267 Upvotes on 2,019 Posts
If you have a Dremel tool it's quick and easy to grind the protruding tip off with the high speed cutoff wheel.
Old 02-23-20, 03:53 PM
T
No, but I may be interested in investing in one.
Old 02-24-20, 03:25 AM
Received 870 Upvotes on 761 Posts
I'd remove that screw and use a shorter one along with tooth pics or whatever glued into the hole to make the shorter screw bite. Then patch the hole on the exterior side.
Norm201 voted this post useful.
Old 02-24-20, 05:42 PM
T
Thanks. What kind of glue should I use?
Old 02-24-20, 09:55 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Carpenters glue of course!
Old 02-25-20, 05:37 AM
P
Most home centers sell a variety of carpenters wood glues in the glue/caulking section of the store. Almost any of them will work since you only need a drop. If you have it around the house you can also use epoxy or even a thick CA.
Old 02-25-20, 07:55 PM
T
What would you guys use to spread the glue in the hole before inserting the toothpicks? Thanks again.
Old 02-25-20, 08:00 PM
XSleeper's Avatar
Received 1,959 Upvotes on 1,756 Posts
Maybe a toothpick, I dunno...
Old 02-26-20, 03:27 AM
I've always just squirted the glue into the hole and then shoved the toothpicks or whatever into the hole before the glue has a chance to set.
Old 02-26-20, 04:26 AM
P
Fingers also work for water based glues and is easily washed off before it dries. If squishing in epoxy with your finger it can be washed off with alcohol. And... don't touch CA with your skin unless you want to glue your fingers together though acetone can be used to remove it.
Old 02-26-20, 08:11 AM
A
Received 287 Upvotes on 262 Posts
Remove the screw, slice off the tip with a hacksaw, and replace the screw.
Old 02-27-20, 09:22 PM
T
OK. Thanks for all your help.
