Modern Table 3 wonky legs
Definitely 2 slot head screws which seem to be wider than my longest screwdriver head. Three of the legs are loose and can't remove the legs because the screws only turn a little either way. You need more pics?
If it's a flat pack (IKEA) type table it could be a quarter turn fastener. If that's the case you can't firm up the legs by tightening the fastener. You might have to shim the parts (between table top and leg) so there is not gap or a slight tension when you tighten the fasteners.
