Dents from screwing beneath white table.
Old 08-02-20, 11:35 AM
Is there an easy way to repair this? The finish is not affected at all, just elevated from the screws below.
Thanks to all in advance
Old 08-02-20, 11:41 AM
Received 3,740 Upvotes on 3,356 Posts
Welcome to the forums.
Technically the surface is damaged. The point of the screw has stretched the finish.
You would need to use shorter screws.
You could use the handle end of a screwdriver to carefully push those bumps back down.
Old 08-02-20, 11:47 AM
XSleeper's Avatar
Received 1,838 Upvotes on 1,654 Posts
You would have to back the screws out first since they are too long and distorted the finish. Either use shorter screws or put a finish washer on before using that screw. Tapping the bumps back down is about all you can do, probably wont be perfect.
Old 08-02-20, 01:31 PM
Thanks for the fast replies. Is sanding and repainting an option for a situation like this?
Old 08-02-20, 01:41 PM
We couldn't answer that without knowing what the white material is.
Accidents do happen and in the past when I've had that happen.... I carefully push it back into place.
Old 08-02-20, 01:49 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Sometimes the repair can be worst than the damage.
See if massaging the dimples works, then evaluate next steps!
Old 08-02-20, 01:51 PM
Norm201's Avatar
Received 702 Upvotes on 624 Posts
I would use a piece of 2 x 4 and a heavy rubber mallet. Put a cloth under the 2 x 4 to prevent marring of the surface.
Old 08-02-20, 05:33 PM
Wow, thanks for all the responses. I ended up banging it down using the rear of the power drill with a cloth layered on-top. Looks much less noticeable now. Thanks for all the help
