Spot sanding and refinishing butcher block?
Old 09-07-20, 06:12 PM
V
I just finished installing butcher block countertops. I came home this evening to a coffee pot that had leaked and I now have a dark stain. Can you spot sand and finish part of the butcher block? I’d rather not redo the entire countertop as I just finished it about a week ago and got it installed yesterday. It’s about an 8” area at the end of the countertop I’d have to redo.
Old 09-07-20, 06:56 PM
XSleeper's Avatar
Received 1,712 Upvotes on 1,536 Posts
You didnt tell us anything about HOW you finished the countertops, so it's its really hard to answer your question. One would assume you could block sand the affected and refinish, but we dont know what you used as a finish.
Old 09-07-20, 08:06 PM
V
I used Watco clear butcher block oil and finish. And then used Howard’s cutting board wood oil as a final coach. I did 3 coats of the Howard’s and 2 coats of the watco.
Old 09-07-20, 08:10 PM
XSleeper's Avatar
You will just have to sand and try to blend it as best as you can. Problem is where it blends in you will have an overlapping area where 3&2 coats meet 6&4 coats. You won't know until you try. And you may have to go by eye.
this is why a bees wax finish is probably superior.
