Cracked interior door around flush bolt
Old 11-13-20, 08:48 PM
My kids are clumsy as hell. Can I repair this using wood or gorilla glue?
Old 11-13-20, 09:03 PM
XSleeper's Avatar
Received 714 Votes on 661 Posts
You would probably need to take it down, lay it on some sawhorses, remove the flush bolt, and then use wood glue and a combination of various clamps to squeeze it together. Squeeze as much glue as you can into the crack... maybe run a toothpick along the crack to force it in. Have a clean rag and some hot water to clean off any glue that squeezes out when you clamp it.
Looks like you would need one 36" bar clamp to squeeze the bottom couple inches together. You can probably do the rest with maybe 3 c-clamps... put a scrap of wood on each side of the door to protect it from getting dented.
marksr voted this post useful.
Old 11-13-20, 09:11 PM
Approx. how long does the clamp stay on?
Old 11-13-20, 09:17 PM
XSleeper's Avatar
I'd leave them on overnight.
Old 11-13-20, 09:18 PM
Excellent. I'll give it a shot. Thank you.
Old 11-14-20, 05:28 AM
Norm201's Avatar
Received 255 Votes on 229 Posts
make sure you use a polyurethane type glue (Gorilla glue). You might want to consider Franklin International 1414 Titebond III Ultimate Wood Glue. Test show this t be the strongest.
FWIW...Gorilla glue will adhere to more substances but Titebond III gives a better wood to wood bond.
