I want to find a bolt like the one attached in this post. It has hex slot, the diameter is 1/4" in the shank. and the length is about 0.9". This is from a chair. I want to find a bolt just like this but with slightly longer shank--maybe 1.25" at most. The problem is this short bolt causes the chair back support to be tilted toward the front. If I can use a slightly longer bolt the back support can be pushed back a little bit. Can I get help finding the name of the product, and if possible, where to find this kind of bolt? I've tried to scour internet with no good result. Grade-8 bolt, hex slot, 1/4" diameter.
A standard hex head bolt with a washer would work to replace that. No need for the integral washer nor hex-drive head. As long as you can tighten it, it's not a big deal.
The 'assemble your own' furniture suppliers like those bolts as it's cheap to include a hex key with the furniture for customer assembly. One of those cheap metal wrenches are harder for most people to use, and it would be"expensive" for them to include a proper assembly tool.
As Marq mentioned, I'm sure you could get a box of 50/100 at McMaster Carr, but your local hardware store will sell you one for about $0.21.
Hey All,
Id love to build myself a desk like this but have a few questions , this is the only pic I could not find any plans .
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/529x385/a0acb251_2548_4021_9c1b_bbb0de2c8c9e_261f2a58c088456b006a9b2c611d9993ac59e236.jpeg[/img]
I have a few questions:
Can this be done without welding? Hope so ...
What are they using as the support beam at the bottom/top and where can I get them .
What kind of glass is that / where to acquire ?
thanks so much ya’ll
Hi all. So awhile back my cat knocked over a soda on my end table which had a mousepad like mat on it. Suffice to say it sat there for a couple hours and left a whitish haze across the top. Was wondering what I could maybe try to fix it. I had tried a light thing of paint thinner but no luck. I believe its a veneer top (just something from City Furniture) so prob cant really sand it. Any help is appreciated. Thx
