Baseboard trim for stairway
Old 04-17-21, 08:25 AM
T
Remodeling left a gap between our closed stringers and the drywall over our hardwood stairs. Presumably we should cover the gap with baseboard, but it will look odd, as the treads and risers are acacia, the stringers are painted, and the baseboard at the landings is poly-finished knotty alder (see photos). Should we just repaint the stringers or is there a better solution?
Without baseboard
With upstairs baseboard
With baseboard over stringer
Old 04-17-21, 08:54 AM
Received 1 Upvote on 1 Post
Have you thought about white baseboard for the stairs (matching the white side boards of the stairs and the walls), then transition to what you showed in the photos for the flat area ?
Old 04-17-21, 09:01 AM
XSleeper's Avatar
Received 1,979 Upvotes on 1,774 Posts
No reason to use a 4" baseboard to cover a 1/2" gap. I would end the stained baseboard at the nosing (returning it back to the wall like it is turning a 90 degree corner) and just put a small white trim on top of the white staircase skirting. Like a 3/4" quarter round, or a door stop moulding.
cwbuff voted this post useful.
Old 04-17-21, 09:14 AM
Received 875 Upvotes on 766 Posts
Door stop was my first thought.
Old 04-17-21, 01:56 PM
T
Great suggestions, thanks all.
