Engine oil smell reeks!
Old 08-19-21, 06:37 PM
R
Unhappy Engine oil smell reeks!
Hi everyone!
I'm just getting into refinishing stuff. I have 4 projects on the go atm. This one is stumping me though.
I found this old shelf on the road. Looks like it was used in a mechanic shop.. smells like it too. I can't seem to get the engine oil smell out. I tried scrubbing with dish soap and a steel wool and scrubbie, then I tried sanding, then I even sealed it will a Minqwax Polycrilic. Still stinks!
I really love the patina and seafoam green. Any recommendations to either seal or remove that smell?
Old 08-20-21, 02:01 AM
Received 867 Upvotes on 758 Posts
Pigmented shellac [BIN] is the ultimate coating for blocking stains and odors. I don't know if a clear shellac would do the same thing or not but might be worth a try. Solvent based coatings do a better job of sealing than water based ones do. Oil base poly should do better than Polycrylic but would have an amber effect on the existing paint.
Old 08-23-21, 03:17 PM
R
Thanks marksr!
I used the Zinsser Bulls Eye clear shellac and it worked great. I used two coats and made sure to fill every crack with wood-filler first.
Old 08-24-21, 03:33 AM
Glad to hear it ..... and we learned something in the process!
