Changing counter top with undermount sink
Old 10-26-21, 12:25 PM
W
Received 1 Upvote on 1 Post
It possible to change this counter top ??
when inspecting from underneath I don't see any mount hardware for counter or even the sink
Old 10-26-21, 12:27 PM
Received 875 Upvotes on 766 Posts
There should be clips for the sink but the tops are often just glued on with silicone caulk.
Old 10-26-21, 12:45 PM
W
If it's just glue. Is it possible to remove or I ll damage the sink . ll look for clips but looks like sink was gluded too
Old 10-26-21, 01:59 PM
Received 1,291 Upvotes on 1,228 Posts
I would start with the assumption you're going to replace the whole thing. If you manage to separate the two pieces without damaging the bowl, great.
Old 10-26-21, 02:14 PM
P
Received 2,324 Upvotes on 2,067 Posts
You can get them apart if you work carefully. Work a box cutter blade between the sink & counter, then try opening and expanding with a thin bladed putty knife. Then when it's opened up enough I use a painters tool to apply some prying force to get them apart. It's a bit fussy and tedious but it can be done.
