Wood Banister Repair
Old 11-10-21, 04:27 AM
K
We have a home that had a golden oak entertainment center and wood banister. The prior owner had them redone in a dark walnut, looks beautiful. Movers scratched the banister and even w/ sanding the area, the stains and touchup pens aren't similar to whatever he put on. Its almost like he painted it, but you can see the wood grain. It also appears he put a semi gloss or gloss over the banister, so I know hat is some of the difference. Any suggestions other than miniwax products which I have and tried? thank you!
Old 11-10-21, 04:36 AM
Received 302 Upvotes on 272 Posts
A picture would be helpful here.
You may have made it harder to hide with what you have done so far.
Old 11-10-21, 05:30 AM
Received 875 Upvotes on 766 Posts
welcome to the forums!
pics would definitely help us help you
Old 11-15-21, 11:38 AM
K
Pictures of banister
The honey oak was the original color, prior owner stained it a dark walnut, lighter in some areas as you can see. The movers scratched some areas and rubbed off others. No local store stain seems to get the deep color here.
Old 11-15-21, 11:57 AM
They might have used a tinted poly like Minwax's Polyshades. Interior wood stains aren't that opaque. You might try sanding it down some [assuming the damage is limited to the newel cap] and then apply 2-3 coats of tinted poly.
2john02458 voted this post useful.
Old 11-15-21, 02:15 PM
Received 1,289 Upvotes on 1,227 Posts
Touching up stuff like that is an art few people can pull off. I'd be inclined to either let it go or be prepared to sand down that whole top and duplicate whatever process you found by testing on scrap wood which met your standards.
