Finish repair?
Old 06-07-22, 01:40 PM
H
Received 1 Upvote on 1 Post
Finish repair?
Hello, can anyone tell me what I can do to repair the finish on this cabinet? Its fairly new and I sat one of those plug in air fresheners on it, not realizing it could leak, well it did and when I wiped it off, it took the dark colored finish off. Thanks, Rob
Old 06-07-22, 02:53 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Simply put, sand it down, re-stain and re-top coat.
I'd say just do the one board but chances are very good it wont match!
Old 06-08-22, 03:00 AM
Received 867 Upvotes on 758 Posts
Welcome to the forums!
Is it solid wood or a veneer?
If you get the stain right, refinishing just one board should be acceptable.
Old 06-13-22, 06:11 PM
H
Hey and thank you, they said it was real wood when we bought it but it, like alot of furniture these days feels kinda like plastic to me.
marykdmn voted this post useful.
Old 06-13-22, 09:24 PM
Received 1,276 Upvotes on 1,215 Posts
Veneer is technically real wood but it's very thin and therefore easy to punch through with sanding.
Old 06-14-22, 03:09 AM
If you pull the drawer out what does the underside of the top look like? If it corresponds with the top the odds are it's solid wood. If it's different [not counting finish] the odds are it's a veneer.
Technically, particle board covered with a veneer is all wood - sawdust and glue is still wood, sad that you can't always trust what a salesperson says
