Apologies if this is not the correct forum for this question. Any suggestions on how I can repair this floor lamp?
A threaded wooden piece sticks up through the middle of the base, and screws into the pole. The wooden threading inside the pole is fine, but the wooden threading on the piece that sticks up through the base is stripped. Threaded wooden piece sticks up through the base, and screws into the pole.
You mean the pole screws onto the wooden piece that sticks up thru the base.
I've never seen a pole screw on to a wooden fitting.
That doesn't sound like a very strong mounting method.
You might try wrapping several wraps of Teflon tape around the stripped thread.
Short of that would be to drill a hole through it and the mating part and stick a pin through it or maybe drill a hole in the mating part and just screw a short wood screw to grab the shaft.
I'm thinking wood glue or epoxy, possibly mixed with sawdust if there are big gaps to fill, to glue it back together. Of, course this would be semi-permenant and will make repairs in the future more difficult.
Hello.
I don't know where else to ask this question because I feel the answer from the woodworker may not be the best. A little under 6 months ago I needed a temporary grave marker. Unfortunately, I did not have the means to engrave or print name & info on anything I could make. I searched online for days and finally settled on a merchant. Family decided on the style and although I had my own budget in mind, I decided against stained pine as I had concerns about outdoor use. I was unsure about quality or other issues would negatively affect look and longevity. I 'splurged' on the Mahagony, believing from some research that with proper care, this was the color/look we all liked.
The company instructs on both their website and on a note included with the product, to apply a new coat of Thompson's Water Seal once a year. The cross looked beautiful when it arrived although I was a little surprised that I didn't notice anything which (in my unprofessional mind,) looked like a sealant. Perhaps this is normal for T's WS and other similar products. The front of the cross has decorative engraving as well as a name and dates. It took a good deal of time and effort to make this memorial secure and welcoming. To my dismay, exactly one month later I returned and was taken back by the change in color of the cross. Not all family members had seen the cross in person when it still had the reddish shade. Less than 30 days after that, I received photos from a sibling. I couldn't believe the further 'decline' and as I enlarged both the front and back of the cross, I noticed an odd 'waterline' around all of the edges of the cross - the bottom too. I contacted the company owner and supplied three pictures from each month and asked why there would be such a drastic look after less than 30 days, and to find further degradation within 60 days. I pointed out that the most recent photos made the (front especially) look so old and weathered and asked why and what could I do to 'restore' it to the original look. I had noted that I was surprised to find online - many sources (including Thompson's own website,) complaining about the performance of TWS, and many comments of repeat users reporting many types of complaints but noting that they felt perhaps the formulation was different than it had been in the past. I asked if perhaps possible and maybe other customers had not contacted them with issues.
The first response indicated to apply a new coat of Thompson's Water Seal, and if the result wasn't to my liking, apply mineral oil. I thought mineral oil made sense if this was an indoor cutting board, but not for outdoor use. Before sending my response, I did some more online research. Hard to find photos of what outdoor Mahagony should look like. Depending upon the site or blog, there are different ways that woodworkers describe the color of mahogany. All I wanted was the look I chose. When I looked at sealing options for outdoor applications, mineral oil did not come up as a recommended choice. And as far as commercial products, there were a number of options considered to be the best - nowhere could I find Thompson's as a woodworker's recommendation.
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/500x530/cbwoodchoices2_727623332bf7d1cf032e22c3eacd18efd43f4cf9.jpg[/img]
[i]Merchant[/i]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/794x665/il_794xn_3080582682_s7whc_b_a3b78256cacbf8bc34e4c1afa30e99cf99bcb145.jpg[/img]
[i]Merchant (center was the look we wanted.)[/i]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1920x1080/mayjunejuly_ed2a856d0c71c08b27e296a10d5b0fe223c61cde.jpg[/img]
[i]Photos of the back only. L-R Brand new, 30 days later and 60 days later.[/i]
In my reply to the owner of the company, I voiced my concern over a new layer of water seal because I wasn't sure if this would just preserve the current look (which is probably so much worse than mid-July) thus showing the drip/watermarks so visible on both sides of the cross. I also asked if the cross was originally stained to give it the color chosen. The owner replied that after looking at the photos she is "confident that a layer of water seal will do the trick," and that it had not been stained - it was purely the TWS.
Sorry for the long post but at this point I have not a clue if this advice is in fact the way to 'revive' the look of the wood. I don't know how I missed any info online that would indicate Mahagony would fade so quickly in the elements. In fact, I do remember sources indicating that outdoor furniture would either get a richer color with time or to make sure yearly to maintain with a good quality sealant to protect against UV and water damage. To me this cross looks like it suffered UV damage within the first 30 day and worsened by the next 30. I don't know what product I should now be purchasing as I tend to agree with others, Thompson's doesn't offer much in the positive department. I see online that my options are large quantities at prices which exceed the extra amount I paid to go with Mahagony over pine. I have no other use for a gallon+. Have no idea if I will need to sand and if so how this may detract from the engraving on the frontside. And whatever the remedy, it has to be done onsite as I do not live in the same state, and I am the 'crafty' sibling who put the temporary grave memorial together.
I've put together in one image, pictures of the back of the cross from May, June & July. Hopefully the fine details (especially July) are viewable and recommendations can be made. Assistance is greatly appreciated.
Read More
This is a old cabinet I've had for years. I was going to get rid of it but friends suggested I restore it. I haven't done any furniture restore and would like to know my best options. It looks like it isn't solid, it has a veneer covering.
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/800x600/20221014_130533_a4eef0c4cf3acf7b3c91cc1382f3739419d2e770.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/800x600/20221014_130547_a74f60c2a8b26ee6c9690d574ed7ef6148ae4f58.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20221016_103343_6c705e4842a5d9fb76d7c4f63ac4eb4021611699.jpg[/img]
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20221016_103352_df8db874be04427d158d74767da405dfa57b85aa.jpg[/img]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20221016_103408_3d30eae94d04875d9e8f6e4c149a71daa6fa8fcc.jpg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20221016_103613_963b99ef5b176d77d63b872f8d6f1c231c008109.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20221016_103649_13637c95bc9c158e81b98ae6025152be3ac905a2.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20221016_103822_54868075c9be7681005ce4655771b2e9e2aeadae.jpg[/img]
Read More
