Drawer rail to cabinet plastic attachment, cannot find it anywhere
Old 01-09-23, 01:42 PM
Anyone know what these white plastic pieces are called, and where I can get them? I've checked our big box stores (HD, Lowe's, Menards) and no luck. There does not seem to be a brand or part number anywhere on the broken piece.
Left rail and attachment piece is good. Right attachment piece is missing the front tab / bracket that holds the metal rail in place.
Front of plastic piece, but bracket holding metal rail has broken off
Rear of plastic piece. The 2 circular posts go into pre-drilled holes in the inner wall of the cabinet.
Old 01-09-23, 02:20 PM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Slide mounts, slide anchors.
Your best luck is going to be to try and identify the cabinets then contact them for parts!
Old 01-09-23, 03:12 PM
XSleeper's Avatar
Received 1,974 Upvotes on 1,770 Posts
See if these are a match. Houck 260 bracket. Click on their installation guide for exact measurements.
MaximumXC voted this post useful.
Old 01-10-23, 01:07 PM
Thank you both. The Houck brackets look promising.
Old 02-18-23, 04:57 PM
It was indeed the Houck brackets. Thanks again, @XSleeper!
Old 02-18-23, 07:01 PM
XSleeper's Avatar
Glad to help!
