refinish interior door
Old 03-20-02, 06:21 PM
Lenny55
Interior door needs refinishing because of damaged corners, scratched finish and areas where finish/stain has been completely rubbed off. Is it advisable to just sand the finish off and then restain? Or should I just use a chemical stripper and take it back to bare wood before I stain and apply new finish? Thanks for help!
Old 03-20-02, 06:27 PM
George's Avatar
Sanding alone may do the trick, but you'll get better results stripping the door and starting from bare, clean wood.
