removing old finish
Old 04-03-02, 07:00 PM
D
removing old finish
I am in the middle of trying to remove the finish from an old table to repair water damage. I am using sand paper to accomplish this but the task is harder than expected. The finish keeps clogging up the sand paper. Is there an easier way to remove the finish and then sand the wood. The finish seems to get sticky when it is subjected to the heat of the abrasive sand paper of belt sander.
Old 04-04-02, 05:41 AM
fewalt's Avatar
daveishere,
Your paper is clogging with finish.
Most chemical strippers should remove the finish. After the strippr waiting period, use a plastic putty knife to remove the residue.
It's less likely to gouge the wood.
fred
