Dresser question
Dresser question
I'm refinishing an oak dresser (varnish, no paint) and have a question. I can't seem to remove the varnish from the sides of the top piece. I've used denatured alcohol, stripper, steel wool, scrubbies, brass brush, tooth brush, everything I can think of. Does anyone have any suggestions? I've run into this problem before with end pieces of tables. Two sides strip well and two don't.
Thanks,
Pat
Thanks,
Pat
Pat:
If you're dealing with a clear finish that's orginal to the piece (factory applied) you're dealing with lacquer - not varnish.
A 50:50 mix of lacquer thinner and denatured alcohol hasn't failed me yet in removing stubborn lacquer finihes - and it's cheaper than any decent stripper I know of.
Use with 00 steel wool and work on about 1 square foot area at a time. Since you're dealing with a very thin liquid here, it would help if you can stand the dresser on one end and work on the other - keep your working surface horizontal, in other words.
