Ginie Garage Door Opener & Home Link system
Old 12-28-02, 11:11 PM
Ginie Garage Door opener has rolling security code technology for theft prevention. How does this work with Home Link system? Home link system (typicaly installed in cars and vans) learn the remote code and then those can be used instade of garage door remote.
To me it sounds like that, Home link systems will not work with this rolling code technology.
Old 12-29-02, 05:18 PM
doorman28/88
homelink will work, it takes some work to tune you car to the opener, but once done its easy.
the first step is holding the remote close to the homelink system and holding the genie trans button down and the homelink button down at the same time till the homelink light flashes fast.
the next step is to find the "learn code" button on your genie opener. look for the hanging black wire which is the radio antenna and that will get you close to the button. on screw drives and chain guides the light cover will have to be removed.
now that youve found the button, push it, then go back and push the homelink button till it works the door(should be 3 times).
good luck
