Craftsman Garage Door Opener Mystery
Old 03-13-00, 08:23 AM
Guest
Post
I have an old Craftsman Garage Door Opener. It is probably 15 years old. The plastic drive gear wears out about once every 6 years so I replace it. This year I replaced the drive gear and the worm gear. The door will only move about 3 feet. It doesn't seem to matter how I adjust the force or distance. Even if I unattach the door, the device on the track will only go about 3 feet and then return. I recently greased the track. Do you have any suggestions?
Old 03-14-00, 04:19 AM
Guest
Post
Bluehen:
If your opener is 15 years old, it has out lived its 7 year life. My best suggestion
is to replace it with a new one. They are not expensive. Your opener is just wore out.
Jack the Contractor
Old 03-14-00, 12:11 PM
Guest
Post
jack is right on your opener is wore out and should be replaced
