garage door cables
Old 04-17-00, 09:03 PM
Post
I have had a new garage door spring installed. Now the garage door seems to go down to far on the concrete and it the door leaves a gap at the top. How can I tighten the spring or the cable to raise the door?
Old 04-18-00, 03:38 AM
Post
Kenneth:
You do not adjust the springs or the cables. You adjust your opener. On the left side of your opener is a little hole where you insert a screw driver. There are two adjustments there, one for closing, and one for opening. Make sure you have the right
one. When ever you make a major change in your garage doors, you have to re-adjust your opener. You need the door to close less. Good Luck
Jack the Contractor
