ice water sprays from refrigerator
Old 07-12-00, 01:16 PM
Post
The ice maker works great in the refrig, but now the water sprays all over. Any ideas out there, it is an amana 25 ft.
D. Truesdell
Old 07-22-00, 07:32 PM
Post
WHERE IS THE WATER SPRAYING FROM? IF IT IS
Old 07-22-00, 07:41 PM
Post
SORRY.. IF IT COMING FROM THE BACK OF THE FRIDGE ON THE FLOOR THE PLASTIC FILL LINE IS OLD AND BROKEN OR CRACKED. IF IS NEW [1YR]OR NEWER THEN THE TUBE IN THE DISPENSER WAS NOT LONG ENOUGH [FACTORY BOO.BOO.] AND WHEN YOU ACCESS WATER IT HITS THE DISPENSER INSTEAD OF YOUR GLASS. IF IT IS THE LINE IN BACK YOU PROBABLY NEED A QUALIFIED TECHNICIAN TO REPLACE IT. iF THE LATTER THEN MOST OF THE TIME A FIRM STEADY PULL OF THE PLASTIC LINE UP IN THE DISPENSER WILL BRING IT DOWN WHERE IT SHOULD BE. GOOD LUCK!
