lift master
Old 05-28-03, 03:51 PM
conlo
lift master
Have a 1/2 HP lift master garage door opener(model 1260) with no manual. On the outside of the motor box you have three screw terminals marked 1.2 and 3. I figured out that terminals 1 and 2 are for a momentary type switch to manually operate it. What is terminal 3 used for?
Old 05-28-03, 05:03 PM
doorman28/88
term. #3 is used for the safety beams, if the unit uses those.the white wire of the beams goes to #2 term., while the white/black wire goes to #3 term.
Old 05-29-03, 02:31 PM
conlo
lift master
Just how much weight can this thing lift ? I realize that garage doors are counter balanced. will it lift a lathe chuck which weighs about 60 to 80 lbs? Mine is a 1/2 HP with plastic gears.
Old 05-29-03, 04:24 PM
sandy2000's Avatar
www.liftmaster.com
Lots of info available at their site
