Increase in OSB prices
I live in a new subdivision and a local builder changed from OSB sheathing to that black board. (Not sure what it's called.)
When I asked him about the change he said that his supplier can only supply the OSB that's in stock because almost all of the OSB is being bought by the gov't to rebuild Iraq. He said that the available OSB is going for $18 a sheet up from $9 a sheet earlier this week.
Anyone heard about this?
Sort of hard to believe but he wasn't kidding about OSB prices going up overnight...
He did say that that black board is fire retardant so it might not be too bad for the shop.
Any ideas about the blackboard with OSB in the corners?
Doug, I got the materials list. Thanks. I'm having the truss factory work up how much it'll cost to have the walls pre-fabbed and delivered...
OSB and Black board are thow different things. OSB is made of wood chips and wood particles. Black board is fire resistant (90 minute rated) sheetrock. The black paper is to keep it from getting confused with white paper regular sheetrock. The shortage has nothing to to with the far east. It is in short supply due to the amount of housing and remodeling done in this country. There are only 2 mills that make it. Alot of our OSB comes from Canada. The price will drop about Thanksgiving. This happens every year.
hoffman,
Glad you got the material list - did the 3d views help enough?
With regards to what you are wanting to do, the alternative to OSB would be the fiber sheathing or the Tuff R sheathing which would give added insulation quality.
Regardless, the use of the OSB at the corners is approved by code and/or the insert of the metal Kerf Type bracing.
You'll have to do some price checking in the area as to what they are charging for replacement sheathing alternatives.
Hope this all helps!
Jack's right about the price.....it generally drops in the winter. I bought several bundles last winter for $4.90/sht. Whenever I know I have a couple projects coming ahead, I buy about January, have it delivered and they stack whole bundles in one of my sheds using the fork truck buggie.
It's $15/sh right now at the local Lowes.
I suspect a person could make a decent return on thier money by just buying a trailer load in the winter and selling it in the summer......though this year is unusually high, most summers it goes to $7-8 range.
Black board "here" is the term for asphalt coated ( one side ) fiberboard that used to be used for sheathing a lot before foams got to be popular. I'd say it's making a comeback now due the price difference. It has about NO strength, only R1.5 rated and is just good to close in a wall. You DEFINITELY have to have OSB, plywood or some type of corner bracing.
A quick search reveals lots of info
"Iraq reconstruction builds plywood demand, prices"
http://www.usatoday.com/money/world/...-plywood_x.htm
