Garage Door Opener
Garage Door Opener
I just purchased a house with two garage doors with openers and no remote. Both garage door openers are Allister ARD Type II.
There appears to be a minor problem, that the lights in the units stay on. Shouldn't these turn off after a while? There is a jumper between the two units connecting 24V secondaries 1&2. Could this be related? Is there some other reason to connect these units in this manner? They have separate wall switches which operate properly.
Also I need remotes.
Unit 1 has the following numbers: on stickers on the rear of the unit:
A00882
1141652
and a cylinder inside "For Motor Starting":
MEDCO ELECTRA
3535B4A0067A250A2
35F4022BA1 67-76MFD
250VAC 60HZ 3628744
There is no external box on this unit.
Unit 2 has similar numbers, except on the outside rear it is:
A00882
1141658
and the cylinder is identical except after
250VAC 60HZ 36288744.
Also unit 2 has an external box attached to 24V secondary 1,2 and 3. This black box is made by Allister, ADD832 318
Can you tell me which remotes I will need to buy to operate these doors?
Thank you for your help.
A00882
1141652
MEDCO ELECTRA
3535B4A0067A250A2
35F4022BA1 67-76MFD
250VAC 60HZ 3628744
A00882
1141658
gsquared ,
You could try these guys, give then a call or send them an e-mail. I'm not that familiar with these brand.
http://www.1stdooropeners.com/allisterindex.htm
http://shop.store.yahoo.com/aaaremot...terpulsar.html
Hope this helps!
Hope this helps!
