shelves across garage
I am looking for some help on hanging shelves in the garage to go across the whole width of the garage.
I know that HD sells a wire kind of shelves up to 24”, I was looking to build a shelving out of a plywood and a lot wider may be 48”
What material can/should I use for the supports and what’s the best way to attach them to the ceiling’s joists?
Thanks,
Thanks,
Newbie,
You can use 2x4's horizontal at 2'-O.C. and same for vertical to attach to roof rafters. 4x8 sheets of 1/2" OSB for shelving.
That should do it. I assume you know what to do from this.
Good Luck!
Good Luck!
