Door opens/closes, but very jerky
I recently had both springs replaced on one of my garage doors (one of the springs had broken). Anyway, I was sure this would fix the "jerkiness" I was seeing when my garage door opener would close or open the door.... WRONG! I had the guy that installed the springs try and troubleshoot the jerkiness and he checked for loose bolts, etc. and even replace the rollers with new nylon ones.. still no good. Just to get the door to go up and down, he adjusted the "force" setting on the opener so that the door will open and close. I suspect a problem with the door rails. Anyone have any ideas on how to troubleshoot/fix rail problems? Thanks.
humptydoo,
I am assuming no on teh first question.
I am wondering if the door track is not plumb vertically?
Break out a 4 foot level and check both sides and front of track. Was the door track hit with a car that might have knocked it out of whack?
No..the door has not been hit with a car. It used to open/close pretty smoothly until one of the springs broke. When the springs were replaced (as a pair), that was when it really got jerky and the rail was wobbling all over the place. The tech that replaced the springs could not find any other problem, so I went out with a flashlight and started checking the door track. I found where one of the bolts that holds the door track on one side near the ceiling had come loose from the wall, so I put some longer screws back in. That made it a lot sturdier. The tech that replaced the springs came out and readjusted them, but, it did not really help with the jerkiness.
humptydoo,
Call the company back to recheck everything - it should be their responsibility! Best thing I suggest as something is not right - maybe there is another bolt or two that are getting in the way of the roller. Check everything!
Good Luck!
Good Luck!
