Adding Garage
Adding Garage
I would like to add an attached garage to my home. I have the room on the side of my home. Here are some problems.
1. Electric meter will have to be moved.
2. Oil Tank- Can it be left where it is, which will be inside the garage when it is built?
3. Chiminey, I have a chiminey that is on that side of the house. Can that be enclosed?
Thanks In advance foe your help!
Your electric meter will have to be moved to the outside, before you start. Not a cheap deal. Your oil tank will also have to be moved to be outside. Your chimney is probably ok. However, the wall between the garage and your house will have to have 90 minute sheetrock installed. It is also called black board. Clear up
to the peak. Good Luck
