Garage door button needs to be pressed continuously to operate
Old 09-17-04, 05:08 PM
sushrut
One of my garage door units is not working properly. The garage door 'button' when pressed once opens the garage door smoothly. However, when I press the garage door button the second time to close the door, the door does not close. I have the keep the button pressed continuously for the door to close. However, when I release the button as soon as the door is closed, the door starts opening again. I then have to press and release the button a few times till the door is at a position close to the ground and stops moving.
Any idea how I can fix this?
Thanks,
Sushrut
Old 09-17-04, 05:43 PM
Take it off and short the contacts, if it doesn't operate from a momentary short, but displays the same requirement, (continiously shorted), the pick-up sensor in your operator needs to be replaced.
Old 09-20-04, 06:10 AM
sushrut
How do I replace the pickup sensor? Is it easy to do? I have a CRAFTSMAN 1/2 HP.
Thanks
Sushrut
Old 09-20-04, 07:51 PM
It will most likely be part of the circuit board. You may have to call sears.
