unlevel frost walls
select O cube ice maker leaks
My icemaker leaks by the motor asembly end. to stop this I keep the sensing arm propped up(actually wedged up) the off position does't catch anymore. the ice maker is about 8 years old.
how do I stop the leaking and how do I get the sensing arm to work again.
thanks
thanks
unlevel frost walls
I just had a contractor build frost walls for my 40x26 attached garage. The walls tapers down 1 inch out of level on the 40 foot length wall. Is this to much taper to build on? Should it be made level before I start to build on the walls or pay for the job? thanks
