Garage Door conversion kits
I have the old style garage door openers that don't have rolling codes.
It is a craftsman 1/2hp opener.
I purchased the rolling code conversion kits. I installed it and it works great. One problem. Cutting the old internal antenna didn't disable the old one. I can still take the old remote outside and get it to open the door. I took the whole circuit board out and I completely removed the soldered antenna from it.
No luck. Any way to disable or reduce the range of the old internal transmitter?
I wouldnt fuss with it. You may damage the board and then you would be stuck trying to find a new circuit board for an old machine, depending on the age, and what safety features it has, they may not make it anymore.
Someone suggested soldering a wire to the antennae and connecting it to a ground. They said that should sufficiently kill the signal.
Honestly, this thing is 13 years old. It works perfectly. If I did break it, I would just buy a new opener. I just felt the conversion kits were a better deal at this time.
2 x Conversion kits = $70
2 x new garage door openers = $300.
If I just had one garage door opener then I would just purchase a new one but since I have to do two openers.
