Converting 2 single overhead doors to 1 double overhead door?
Old 01-27-05, 07:12 AM
jeepgal98
I have two single overhead garage doors. Is there any way to convert them to one double overhead garage door? I have a sitting room above the garage, and between the doors are supporting studs.
Thanks!
Old 01-27-05, 05:26 PM
IHI's Avatar
IHI
IHI is offline
Yep, just a matter of building a temporary wall to hold up the side of the garage you want to convert and then taking the necessary steps to knock out middle section, lay new brick, frame new walls and reside.
Obviously more work than that, but simple as that none the less.
