painting garage in summer heat
Old 07-29-06, 05:51 AM
T
I really need to paint my garage in the few days that I have off work, the problem is I hear it's not good to paint in high humidity. What can go wrong if I do and what are my choices to get the job done in this 90+ deg heat and high humidity? There is no relief in sight for the next week.
thanks.
Old 07-29-06, 06:17 AM
Received 862 Upvotes on 754 Posts
The biggest problem with painting in high humidity is that you will sweat more
As long as you are using latex there shouldn't be any problems. The paint will dry a little slower. Oil base would only be a problem if the surface has obsorbed any moisture.
If you can paint where you are mostly in the shade it will be better for you and the paint. Might want to make a big jug of ice tea
Old 07-29-06, 09:11 AM
W
Received 26 Upvotes on 21 Posts
I would rather paint in 90* weather than 40*. Watch how the sun hits your garage. Plan your job so that you paint the sides that get a lot of sun early/late in the day. Paint the shady sides at mid day.
Old 08-06-06, 04:31 PM
T
Red face thanks
Thanks marksr and Wayne. With alot of sweat and even more 10 min breaks the painting went well. The ice tea helped alot as the sun chased me around each corner! Thanks again.
Old 08-07-06, 04:42 AM
Glad we could help and now you can proudly brag you DIY.
