Quieter garage door operation
Old 11-07-06, 08:40 AM
W
Question Quieter garage door operation
First of all, allow me to lead off by saying that I have FULLY explored this topic. You might not tell me anything I don't already know. But I think I am looking for an EXTREME solution here....
TWO questions.....
1) Are there any manufacturers of RUBBER (not nylon) garage door wheels? (If they can put trains on them, why not garage doors?)
2) If (1) above is 'NO'.....has anyone thought of gluing a thin rubber strip onto the bottom of the track?
Thanks!
Ted
Old 11-07-06, 03:48 PM
Doorman2722's Avatar
Received 42 Upvotes on 41 Posts
Nylon is the only thing I know of. Gluing rubber to the track may work, but may increase the chance of the rollers falling out. A lot of the noise can come from the door opener it's self. A nice belt drive opener with nylon rollers is darn quiet.
Old 11-07-06, 03:50 PM
W
Received 24 Upvotes on 20 Posts
Warped -If you start off by telling people they aren't going to tell you anything you don't already know, they probably won't.
Old 11-07-06, 07:49 PM
T
To reduce noise, you isolate the source. Put rubber grommets between all through bolts, and make sure the door is adjusted correctly. Rubber rollers will not work, but nylon ones will help. Most noise is transmitted through the opener and the opener track.
Isolate is the key word.
Old 11-07-06, 08:57 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
If the door dont have insulation in it put some in. That will sure help.
Old 11-08-06, 03:10 PM
HotxxxxxxxOKC's Avatar
Thumbs down
If you FULLY explored the topic, then you would already have your answers.
