What's a recommended ceiling?
Old 02-12-07, 07:59 AM
B
I am getting ready to hang some florescent light fixtures in my new garage/workshop and am trying to decide what to use for my ceiling. Should I use drywall, 1/4 inch plywood or what?
Thanks in advance.
Old 02-12-07, 08:11 AM
Received 408 Votes on 364 Posts
Drywall is probably the best choice. 1/4" ply would be too flimsy without the addition of extra framing. I have seen a few that used 1/2 osb and even the stryofoam insulation boards.
Drywall makes for a nicer ceiling and painted white will help to illuminate the space.
Old 02-12-07, 01:24 PM
B
Thanks, I'm assuming you mean 1/2 drywall.
Old 02-12-07, 03:40 PM
While 5/8" drywall makes a better looking ceiling, 1/2" is often used with decent results.
Old 02-12-07, 05:00 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
the same steel that is used for the exterior walls of pole buildings
You can get it any color you want. (although white is a good choice)
it is not affected by moisture
It does not sag with age
It is very hard to put a hole in it when I get po'd and throw a tool. (I didn't say that out loud did I?)
Old 02-13-07, 07:04 AM
Probably ought to point out that steel panels can be more difficult to install - especially if the room is out of square but it would cut out the need for finishing and painting.
nap
I wouldn't worry about a thrown tool denting the metal, I'd be afraid it might come back down and dent my head
Old 02-13-07, 07:15 AM
I would think that metal would be easy for condensation to form . I am an OSB guy. Cheap, easy to install, and you can hang things from it anywhere you like. You can even paint it white or whatever.
