Dirt fill to raise frost line
Old 10-10-07, 11:25 AM
B
So I am building a pole barn and I have got my post holes dug and I have begun set them. I Live in Upstate ny and my building inspector told me to go 42" to 48" to get below the frost line. I got all of my holes very close to that despite the fact that I'm sitting on a rockbed. So just for good measure I was wondering if I backfilled the entire area with a few inches of fill would that actually help the frost depth? By a few inches I mean 20 yards worth of clay/soil fill. So my calculations put that at about 10" for my 24' x'24 area. any info helps / also what is the advantage of using quickforms to pour your concrete in?
Old 10-10-07, 04:20 PM
Received 98 Votes on 86 Posts
Your building inspector would be the best person to ask, since his opinion counts.
Old 10-10-07, 06:15 PM
Better ask your inspector. I did that once on a job, and they called me on it. But I BS'ed my way out of it. You had better ask. Good Luck
Old 10-10-07, 07:47 PM
GregH's Avatar
Super Moderator
Received 54 Votes on 50 Posts
Based on my experience what you propose won't work.
The frost not only moves down but will travel sideways as well.
Here the frost averages 8 feet and can go as deep as 12 feet.
Old 10-11-07, 06:11 AM
logcabincook's Avatar
Wow Greg! How on earth do you guys build houses up there??
budd, did the inspector not consider the rock bed an acceptable stopping point? We have a 48" pier depth requirement as well, but if you hit solid rock, the inspectors call it good since it's very common to hit solid granite during excavation.
Old 10-11-07, 10:18 PM
B
Well the inspector came to inspect my hole depth and told me I was all set to move on. I guess I'll just skip the fill and save a few bucks. THanks for the input.
Old 10-12-07, 05:24 AM
I never thought about it because there's nothing but sand where I live, but hitting rock probably does change things a bit.
