Broken Window Pane
Received 0 Votes
Broken Window Pane
I have a broken window pane in my garage door. The frame appears to be one piece. How do I remove it to replace the glass. I believe the channel in the rear needs to come out though I have pried and it doesn't seem to move. HOW DOES IT COME OUT????
Received 0 Votes
Door material??? Wood, metal??? Most newer window frames are plastic, and the removal of the glass or plastic is fairly easy to figure out. Wood usually comes out from the outside by removing the trim around the glass.
