Opener hums, won't open door
Old 01-16-08, 11:43 AM
Question Opener hums, won't open door
We have a Craftsman chain-driven opener, at least 6 yrs old. (Sorry, Jack, it came with the house.) When either the wall button or the remote button is pushed, the opener hums/buzzes twice and then goes silent. There's a yellow light on the back of the opener next to the transmitter reset button that's flashing. It flashes 5 times, pauses, flashes 5 times, etc. I imagine it's time to buy a new one, but thought I'd check here to see if I can get the old one to work in the meantime. Any suggestions? Thanks!
Old 01-16-08, 03:42 PM
Doorman2722's Avatar
Received 9 Votes on 9 Posts
is the opener in the open/up position?
Old 01-16-08, 04:14 PM
Sounds like the gear is stripped........Pull off the cover and you'll probably find alot of white shavings...Not too hard to change just have to drop the motor down to get the gear off.......Good luck
Old 01-16-08, 04:16 PM
Not anymore. It stopped working after opening the door, but after we tried to figure out the problem, it is now in the closed position.
Old 01-16-08, 04:31 PM
Not the garage door, the opener trolley. is it all the way in the up/ open position. Look at it closely I'll bet it is jammed against the 5/16 bolt, just in front of the motor unit. If so loosen the chain adjuster until it is no longer jammed against the bolt, run the opener down a few inches and then unplug it. Re tighten the chain, then you need to back off the open limit on the left side of the opener so the trolley can't travel as far up again.
Old 01-16-08, 06:26 PM
Thumbs up
I knew what you meant! However, my darlin' husband pointed out to me that I answered incorrectly. Duh. The trolley was indeed in the open position. We did as you instructed and the problem is solved (as you knew it would be)! Woohoo!!! I have no idea why, after all these years, the door would suddenly decide to open too far, but I don't really care. Thank you so much for your expert advice, Doorman!!!
Old 01-23-08, 09:14 PM
Garage Opener hums but does not open the door
I too have a similar issue.
I have a LiftMaster 1/3 HP garage door opener. Until a few days ago it was working well. Now when I press the electric button or the remote button the motor hums but won't open the door. I am able to open the door in manual mode using the red string. In this mode it stops at all positions bot on the way up and down.
I did pull back the trolley a little and when I tried to operate it it moved to a close position. I tightened the chain a bit but with no avail.
Please help me undertsand what the problem could be and if it needs a processional to fix it.
Old 01-24-08, 02:42 AM
Your problem sounds like the plastic gear inside has stripped. see here http://forum.doityourself.com/showthread.php?t=194172
Old 04-04-08, 04:55 PM
Thumbs up The motor does only a quarter turn
As advised by you I replaced the plastic gears that were worn out. Got the kit from Sears for $30.
After fixing it all up the motor just does a quarter turn one way then the other. What could I have done that makes this happen?
Please advise.
Old 04-04-08, 05:43 PM
That is an RPM sensor failure did you hook everything (Wires) back up properly and remember to put the black disc back on the end of the motor shaft
Old 04-22-08, 09:26 PM
Everything is connected and in place.
Should I readjust the up/down screws?
The shuttle that moves between both the sensors does not move back and forth. It stay fixed in between both sensors.
Old 04-23-08, 03:27 AM
Then you forgot to reinstall the little white plastic gear that drives the worm gear that drives that little shuttle your talking about
With that said you still have an RPM sensor problem, because without that little shuttle moving and making contact, the motor would just run and never shut off. Not "just does a quarter turn one way then the other"
Old 11-29-08, 06:10 PM
Mr doorman2722..I to have a similar problem. The trolley is not jammed and when I open the door manually it moves fine. how can I readjust it so the opener works again. any help would be greatly appreciated.
Old 11-30-08, 04:04 AM
What is the opener doing or not doing?
Old 07-07-11, 04:09 AM
I have the very same issue. The opener hums but won't open the door. The door is free and very easy to lift. I recently had the torsion spring replaced. This deal started about 2 months later - hums, won't open. If I leave it for a couple of days it opens again for a few days then hum, won't open. I've checked the path along the chain, free of anything that might catch. I've checked the sensors, even moved them and re-aligned them, still does the same thing. One thing I've noticed from these posts is that people state the door should open manually and stay in the position I leave it in? When I open mine manually, it falls (slowly) to the ground. I have what appears to be an older model Home Depot opener? One other thing I noticed is that the small green LED, for the receiver?, is flashing. The door operates the same whether I use the remote or the hardwired button. Does this mean my opener's on the way out? There's no grinding or screeching when the opener does work, very quiet now with the new spring. Thanks a bunch!
Old 07-07-11, 07:13 AM
Random flashing of that LED is normal. It sounds like you may have a start capacitor that is going bad. A model number would help.
Old 07-20-11, 03:24 PM
Sorry for the late reply... it's a Home Hardware Home Builder system (The Protector System 1/2 HP). I can't find a model number specifically but the part number is 41A4252-7B - actually, that would be the logic board on the opener I'm guessing (after a little googling ). I'm not sure where to find the model number? There's a panel on the back, the logic board, but it only has the part number, FCC number and a Canada number listed. I can't see a specific model number anywhere?
Old 07-21-11, 06:47 AM
The model number should be on the end opposite the logic board but we now know it is a Chamberlain opener by the part number you gave. The start capacitor lies next to the motor and is available at any good door service company in the yellow pages.
Old 07-21-11, 04:02 PM
Many Thanks, I appreciate the help.
Old 03-07-12, 03:02 PM
same humming but not gears
Glad I found this thread,
I have the same humming and no movement issue.
I took the opener apart. The motor shaft seemed stuck, with all the gears off it would still just humm.
I turned it by hand a few times by hand, that got it going but was very noysy. After a few runs it was stuck again.
Based on this, can any one guess if the motor is hosed, or could there be some bad shaft bearing?
Thanks!
  #21
Old 03-08-12, 01:29 PM
Sounds like it could be a bearing problem.
  #22
Old 08-05-13, 09:03 AM
legacy garage opener - similar problem
hello all, I'm experiencing a similar problem: the opener makes a humming noise and doesn't open the door at first. If I pull down the manual release it then works again, and will even open and close the door multiple times. However, if I leave it for 15 minutes and come back again, I experience the same problem. Any help?
  #23
Old 08-29-13, 06:34 AM
if your trolley is not jammed against the 5/16 bolt then it's the motor capacitor. half the time if the capacitor is bad it will show signs of leaking oil. if it's jammed against the bolt i usually take the cover off and a pair of channel locks to turn the motor shaft (short stub shaft opposite end of worm gear) a few turns to unjam it from the bolt.
after you unjam it, clean the limit switches with a razor knife so they make good contact. older limits were copper and they would oxidize over time. humid climates especially. basically the door/trolley has to stop before hitting the bolt. oxidized or bad limits will cause the trolley to jam.
  #24
Old 09-03-13, 05:35 PM
Garage Door Opener Hums for 3 seconds, then goes silent
I have a Liftmaster Garage Door opener Model 1265LM. It was not operating two weeks ago; I would get two clicks out of the unit and LED would flash 5 times but no door movement. I unhooked the carriage and the door would operate fine manully.
In reading previous posts, I determined the board was shot and replaced it. Now the unit only hums for three seconds, then stops with still the LED flashing 5 times.
The carriage is next to the door, not the stop bolt. One side of the chain is extremely tight, the other sags. The capacitor looks fine. The plastic gears were replaced 3 years ago and look fine.
If I unloosen the carriage, the side with the sagging chain will just sag more. I'd like to remove the chain and see if the motor will run but the chain is so tight I can't get it to move. There is no 'stub' on the other side of the motor to turn the motor by hand.
Any help to further diagnose would be appreciated.
  #25
Old 09-04-13, 06:34 PM
my trolley is jammed on the other end at the door not the bolt. There is no way I can turn the motor shaft as there is not enough 'stub' sticking our the motor to get a channel lock on. I'd like to at least be able to move the trolley and/or get some slack in the chain so I can see if it's the motor or capacitor.
Is there a way I can check the capacitor without getting my butt fried?
