Garage door won't open more than a couple inches
Old 06-30-10, 11:41 PM
K
Question Garage door won't open more than a couple inches
I've got a Sears Craftsmen garage door. It was working fine and then all of a sudden it would only open about two inches. I adjusted the tension to the highest setting hoping this would pull the garage door up, but it didn't. I put it in manual and tried to pull the garage door up, but it couldn't be pulled up more than about two inches. I checked the rails on the side and there are no obstructions at all. What could it be?
Old 07-01-10, 03:24 AM
Doorman2722's Avatar
Received 26 Votes on 26 Posts
check your garage door for a broken spring or it may have gotten accidentally locked.
Old 07-01-10, 08:18 AM
K
Where are the springs? On the rails? At the control unit?
Old 07-01-10, 11:14 AM
G
Received 2 Votes on 2 Posts
If you released the opener from the door, and physically could not lift the door more than a few inches, it definitely sounds like a spring. Look above the door and, if you see a heavy metal rod with a spring wound around it, that is a torsion spring and it has either slipped, or more likely broken. Call a garage door specialist as this is not a DIY project.
