continuous hinge on a shed door
Old 09-20-10, 02:46 PM
U
how do i install a piano hinge on my door and frame so they are both flush when closed and do i hinge my door and verticle frame together, then hang the assembly to the shed
thanks
Old 09-20-10, 04:09 PM
D
Received 1 Upvote on 1 Post
Do you need to open the door 180 degrees or is 90 ok?
Old 09-20-10, 04:25 PM
U
i prefer 180, so the door is out of the way
Old 09-20-10, 05:27 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
The hinge pin part of the hinge will always stick out (not be flush) if you want it to open outwardly. Curious question.....why must the hinges be flush, and why do you want to use a piano hinge??
Old 09-20-10, 05:37 PM
D
The hinge will not be flush in order to open 180.
Open the hinge all the way until it forms a 90 degree angle. Set the hinge on either the door or jamb. Predrill the holes and then screw in. Remove it and place it on the other side to do the same thing. I recommend putting in 3 or 4 screws on each side at first, then hang the door and finish the rest with it hung.
Old 09-20-10, 06:50 PM
U
what type of hinge would you use
thanks
Old 09-21-10, 04:24 AM
chandler's Avatar
Standard 3" door hinges..................
