Door Header for Post and Beam Barn?
Received 0 Votes
I'm putting an exterior prehung door on my barn. The barn is post and beam (at least that's what I think it's called). The "door" that's in there now amounts to a few planks of wood with hinges and a latch so there's no header - I assume because there's no downward load there. Do I need to put a header in before I install the door?
"Header" probably not, but you will need to put some lumber in there to frame out the door and to nail siding/molding to. In such an instance, you could install interlocking 2x lumber on the sides and top, spreading the top plate between supports. Of course we can't see what the framing looks like, so "post and beam" it is.
Received 0 Votes
Chandler -
I just reread your post. The opening is framed - with 10 inch posts on both sides. The beam is about 8 feet or so high but no "header'. So the rough opening is already there - minus the header. The current door is basically a shed door - 1X8 boards with cross pieces hung on hinges. I guess I needed to know if the top of the new door frame would need something to nail into. I'll still see if I can post a pic or two this weekend. Thanks so far.
Received 0 Votes
I've provided a link to some pictures I took of the rough opening for the barn door.
The posts are 8" X 8". As I hope you can see, there are two 2Xs toe nailed at 80" with a space inbetween. If I'm going to use a standard door I think I'm going to have to cut out 2" or so to provide enough headroom for the new door.
https://plus.google.com/?tab=qX&gpca...01917041959266
Let me know if my description makes sense and you can tell what's going on from the pictures.
Can't access the pics, but your description is correct. You need 81 1/2" from the floor to the "header". You didn't say what the spacing was from post to post (width).
Received 0 Votes
I think I fixed the pic access problem. When you get a chance let me know.
https://picasaweb.google.com/1011997...01917041959266
https://picasaweb.google.com/1011997...01930057223954
https://picasaweb.google.com/1011997...01973308583714
Width will be right for a 36" door. If all you have is 80", based on the construction, I would consider trimming the bottom of the door. Will you be using a factory door, in frame, with threshold? If so, then go back to plan 1 and make the opening 81 1/2" high.
Received 0 Votes
Yes, I was hoping to use a factory door with threshold without trimming it. I think I can cut the 2Xs and the siding to make room height-wise. I've been thinking I could fill in between the two 2Xs with additional 2Xs.
