Genie Garage Door Opener problem (see video in link)
Received 0 Votes
My Genie chain guide garage door opener is not closing all the way. When it gets about a foot or so off of the ground, the motor makes a large popping noise and the garage door goes back up. I attached a link of the garage door closing, note the noise right before the door goes up.
Genie Garage Door Opener problem - YouTube
Any suggestions? Thanks in advance!
Received 0 Votes
No, the wall is not newly framed. It's the same wall, and garage door opener, from when we moved in 8 years ago. The problem just started a few weeks back.
I do have 2 adjustments on the motor (force open and force close). Messed with them both. It will not close all the way, even with the force close turned all the way up.
Thanks for the response though...
Received 0 Votes
Garage Door Opener 1 - YouTube
Garage Door Opener 2 - YouTube
Garage Door Opener 3 - YouTube
Here's a few more videos at different angles. I have the entire "shell" of the trolley pulled off. The system is quite a bit shaky when coming down.
I also noticed that the black plastic piece in the front, where the light bulb comes out, is bent at the top, and broken off at the corner by the bolt. Could something be hitting that?
With that much vibration in the head, there may be gear damage inside. That's the only thing I can see. Not sure what plastic piece you are talking about, either.
Received 0 Votes
Just cruising by..........
I just happened to join this forum today and noticed your posting on a Genie garage door opener. I have issues with my brand new Genie opener but will start another thread.
I had a similar type problem like yours and mine was pretty simple. Those pesky lights at the bottom of the door had a spider's web/nest in front of one of the lenses!
BTW, my old Genie opener lasted 11 years before going out. I found out that the average garage door opener lasts about 10 years.
Good luck.
Good luck.
Received 0 Votes
Genie ChainGlide Problem
Firstly, this is the cheapest of cheap Genie openers and they no longer manufacture this machine. What your problem is, is what was mentioned above, the plastic housing is broken. The chain on this opener is sucked into the motor head and wraps up on top of the motor. The chain glides in the top of the motor have broken and the chain isn't properly feeding out. Get a new opener and enjoy no more hassle, because putting 1 cent into this ChainGlide is a waste of money. Get a conventional chain opener (runs like a bicycle). This ChainGlide opener was some engineer's pride and joy on paper, and a bad idea in the field. Everything in this opener is plastic.
Top see what the top looks like, here is a picture:
http://lib.store.yahoo.net/lib/aaare...tine175pix.jpg
Either that chain path is broken, or the housing that holds the gear in place has broken. The gear housing uses 3- 4-5" screws to hold two pieces of plastic in place to hold the drive gear.
Get a Liftmaster/Chamberlain opener and be done messing with your garage door opener!
Received 0 Votes
Garage Door opens, but won't close
I have an old Genie 450 Garage Door. I have an issue where I press the Garage opener button once to open, it opens. When I press it again to close, no response is given, but I hear a clicking sound coming from the radio unit. I have tested this out on my remote as well with the same result. As the door is in the up the position (at the limit mark). I went to press the close with no response. I pressed it again an the door went past the limit mark, only to stop at the very end of the rail.
Does anyone have any tips or solutions to my problem?
