Craftsmen garage door opener model 139.53985d powers off while going down
Old 11-06-12, 10:11 AM
The door will not close it gets just passed the halfway mark and powers off. No flashing lights just shuts off completely. I have to hit the bottom of the opener to get the power back on.
I tried this will no door connected and it still does not work.
Greased everything I could, checked sensors and i tried increasing/decreasing the speeds and nothing works.
The opener is from 2006 and if anyone could help me it would be appreciated since this has very annoying!
Thank you!!
Old 11-06-12, 01:16 PM
Received 2 Votes on 2 Posts
If you have to hit it to make it work, you need to be checking inside the housing for a loose or corroded connector. With the opener unplugged, check all connectors and if there is a circuit board, remove it and clean the contacts with a pencil eraser. Make sure that you re seat it firmly.
Old 11-06-12, 02:03 PM
Gunguy45's Avatar
Super Moderator
An ink eraser is better...if they still make such things. I was taught that back in my Navy days in micro/miniature circuit board repair. Something about oils or contaminates on pencil erasers? Not that I wouldn't use them if thats all I had....just saying what I remember.
Old 11-07-12, 06:38 AM
Thank you I will try this method.
On a side note last night I checked the connections and all looked ok.
But I did not remove them so I will not remove them and use the eraser as noted.
Regards!
