Garage door springs
Old 02-03-14, 01:29 PM
F
Garage door springs
I need to replace my springs. I know I have to weigh the door ( 9 x 7 ). What I don't know is - once I have the weight, do I split that between the 2 springs, or do I get each spring rated for that weight.....in other words......
If the door weighs 200 lbs. do I get 2 x 100 lbs. springs, or do I get 2 x 200 lbs. ?.
Thanks.
Old 02-03-14, 02:08 PM
Received 1 Upvote on 1 Post
Look on the outside of the springs.
There should be a color code right on the spring that will tell which one to buy.
garage door spring color code - Bing Images
Old 02-03-14, 02:22 PM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
IIRC...and it's been a while...if the door is 200...you get two springs rated at 200. Pretty sure it says on the package/label.
If you buy a 2 pack at HD, Lowes or similar...the instructions are pretty clear.
Old 02-04-14, 08:42 AM
L
If you use two springs and your door weighs 200 pounds, then you will need two springs rated at 100 pounds each. Here is a real good web site with tons of great info:
Standard Garage Door Torsion Springs
I have ordered springs from them as well, good and quick service.
