Garage door replacement problem
Old 07-27-14, 11:47 AM
T
I replaced my wood garage door with an Ideal brand metal door. I followed the instructions to the tee, but when I tried to open my door the cables became tangled up on the roller drums, causing door to become crooked. I'm thinking my tracks may be out of plumb somehow, although I measured everything as suggested in the manual. I can't think of any other reason for this, any ideas?
Old 07-27-14, 11:52 AM
chandler's Avatar
Received 6 Votes on 6 Posts
How did you roll the cables? Did you tighten them? Very dangerous thing to do on a DIY basis.
Old 07-27-14, 12:11 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Are the drums on the right ends? I've installed a few doors and tangled on the drums sounds like either drums installed wrong or no tension. Does your's have the EZ Set torsion springs?
Old 07-29-14, 10:57 AM
T
Thanks for the reply, yes the drums are correct, I determined that my track was too close to the wall, causing the door to bind. I do have the EZ torsion springs, and once I adjusted the track out the door opens and closes perfectly.
Old 07-29-14, 11:01 AM
T
Well, I figured out the issue was in the track placement, however after watching the video that came with the door, I saw that I rolled the cable the wrong way. I fixed it and it works great. Thanks!
