Are there replacement windows for garage doors?
Old 12-22-14, 02:31 PM
D
Received 1 Upvote on 1 Post
My garage door is probably about 14 years old. It has 7 rectangular windows in the top panel. It looks like a plastic window held in place by a frame that is screwed into the panel.
I would like the idea to change to frosted panels and possibly get some more insulation.
Are there replacement windows? Or snap-in add-ons?
Old 12-22-14, 02:44 PM
Received 759 Upvotes on 664 Posts
I've never worked on garage doors other than painting them and unless I'm mistaken every garage door with windows that I've painted had single pane glass. The few that had cracked glass that I had to replace we just measured and had a sheet of glass cut to fit.
Is your garage door metal or wood construction?
Old 12-22-14, 02:49 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Depends on the brand...but most manufacturers offer multiple options for replacement windows and snap in decorative inserts. Any glass shop could also help you out if you take an example to them. They need the exact size and thickness.
Old 12-22-14, 08:55 PM
You can buy frosted window film, whole lot easier then messing with the windows.
