garage door light.
Old 03-18-15, 06:09 PM
G
garage door light.
I have an automatic garage door with a sears opener. Typically when the opener button is pressed the door operates and the light on the opener lights up the garage. After the doors up for awhile the light automatically turns off. If you cross the sensor beam the light is supposed to turn back on. It has stopped turning on if you cross in front of the beam now, yet it still goes on when the opener button is pressed. The door still auto stops if you cross the sensor beam during lowering so thats still working. Checked all wires and they appear to be connected by the sensors and in the back of the opener unit itself (LED lights on both sensors are on and one flickers if blocked). Any ideas why the sensors no longer trigger the light to go on?
Old 03-18-15, 08:44 PM
Piddler's Avatar
This is only a guess. Something in the system has gone bad (obviously) or (here's the guess part) the sensor beams are not perfectly aligned anymore.
Old 03-19-15, 02:13 PM
G
since the sensors have not been moved and they still react to something blocking them causing the door to go up i would assume their alignment is okay. Was thinking that maybe replacing the sensors would help though they seem to be operating.
