Concrete Paint or Epoxy Garage Floor?
Received 0 Votes
Hi,
I was wondering if I should paint the concrete floor in my garage....or should I Epoxy it?
Would Epoxy flooring decrease the value of your house? Has anyone regretted doing so?
Not sure if I understand what you are saying
Epoxy paints dry to a harder film and generally wear better than other paints. Personally I prefer a concrete stain over paint. The prep for stain isn't as critical and if/when it fails, it basically just wears off [easy to recoat] A successful paint job requires proper prep and no moisture under the slab.
If you do either (paint or epoxy) incorrectly then it could decrease your home's value if it peels or looks bad. Done correctly I think the epoxy could increase your home's value but I don't think paint would increase it.
Received 0 Votes
Hi,
I would suggest you should choose epoxy coating over concrete floors. They provide you with durable, resistant floors along with moisture absorbing qualities. Also, they provide clean floors so looks more spacious. Even, they don’t require maintenance, if handled properly.
btw - welcome to the forums epfloors!
I have worked in facilities that had professionally installed epoxy floors and to say they require no maintenance is an absolute lie. They do wear well and the maintenance is fairly light, depending on what is driven over the floor, but they most assuredly DO require some routine maintenance.
lots of diy'ers regret using epoxies however they usually pick what's sold in apron/vest stores or on the shelf of the local h/o sher-wms,,, we've switched to sher-wms & find their pro mtls to be excellent ( no $ interest ),,, there is NO paint that's suitable for conc,,, IF paint were a good coating, why do we have to repaint our houses ? ? ?
pro installed epoxy floors generally give 7 to 9 yrs of decent performance w/o much maintenance other than sweeping up the abrasives,,, HOWEVER, most industrial floors ALSO have a urethane top coat to protect the epoxy.
we use moisture barrier epoxies but if there's a moisture absorbent epoxy on the market, i think ep's the only guy who knows about them,,, none of my suppliers do,,, as w/anything, proper prep is the key !
