Attaching shed to cement slab.
Old 04-04-01, 09:30 AM
nclement2
Question
I currently have a 8x10 aluminum shed on a 10x10 cement slab. I want to replace it with a 10x10 wooden shed. My question is: How do I anchor the wooden shed to the cement slab? What would be the best, most secure, way of anchoring? I've heard of epoxy anchors, but I have never seen then used before. Has anyone useed them before and if so, are they easy to install?
Any help would be appreciated.
Thank you,
NClement2
Old 04-04-01, 04:25 PM
Guest
Epoxy anchors work very well but are probably overkill. Redheads, or any other concrete expansion bolt will hold a 10 x10 shed where it is forever. I'd use either 3/8 or 1/2" bolts 3-1/2" long. Put one in each corner, either side of each doorway and every 32" in between.
Old 04-04-01, 04:27 PM
Handycapable
You could bolt the bottom sills down two ways. One is to install studs into the concrete and use a washer and nut to hold the sill. Or you could use concrete screws. Something coated would be your best bet, because they will get rusty eventually. Don't forget to use a vapor barrier between the wood and concrete.
