Sunlight on Safe T Beam Sensor
Old 11-10-15, 04:46 PM
H
Received 5 Votes on 4 Posts
Can this cause the door not to open properly? The door opens a few inches and reverses. At this time of year the sun hits the sensor when the door opens. I thought the safety system only affected the door closing.
Old 11-10-15, 04:48 PM
chandler's Avatar
Received 6 Votes on 6 Posts
You are right, it should never reverse itself in a up mode. Have you checked the up pressure setting? Generally the cross beams are shielded enough to where sunlight usually doesn't bother the spectrum of light they are putting out.
Old 11-10-15, 05:41 PM
czizzi's Avatar
Received 15 Votes on 13 Posts
Check to make sure a spring has not broken. If the weight is too much it will over ride and not open he door. You could also try changing the sides of the safety beams, swap left to right to see if that helps.
Old 11-10-15, 05:52 PM
H
Springs have been replaced, but too much resistance may be the culprit. This is a rental and some previous tenant sprayed some unknown sticky crap in the tracks. The door is pretty jerky. Will advise owner to clean and lube tracks, not with WD40. I like TriFlow.
Old 11-10-15, 06:57 PM
G
Received 2 Votes on 2 Posts
As to lubing the tracks, nothing works best. Any lube will attract and hold dust. Lube the axles of the rollers and the hinges.
As to the sensors, it is best to have the receiving sensor looking away from the sun, so it does not get blinded.
