Grandmas garage door broke, please help me
Old 01-06-16, 10:03 PM
N
Hi all,
Tonight my grandmas garage door broke. It opens like 2 feet off ground and then starts shaking so I stopped trying. I believe the bracket was somehow damaged. The garage door has the metal attached to the door; however, near the top it is extremely bent and when the door tried to rise it looked like the actual garage door was being pulled in. I would prefer to save her money so if I can fix it I will. Any tips? Also, I can post a picture of the damage if I can figure out how. Thank you so much to anyone who takes the time to help me and my grandmother out.
Nolan
Old 01-06-16, 10:59 PM
Received 1,399 Votes on 1,296 Posts
Welcome to the forums.
Glad to help you and a few pictures would be very helpful. http://www.doityourself.com/forum/el...-pictures.html
Old 01-07-16, 04:42 AM
czizzi's Avatar
Received 15 Votes on 13 Posts
Possibly the springs or a spring has broken. Depending on the extent of the damage, there may be little that can be done to salvage if the top panel is bent too badly. Will await for pictures to provide better direction.
Old 01-07-16, 07:57 AM
the_tow_guy's Avatar
Received 64 Votes on 53 Posts
Busted spring was the first thing I thought of, too.
Old 01-07-16, 09:02 AM
N
[IMG]http.jpeg[/IMG]
This picture should work I think but I am having some trouble because posting it from phone
Old 01-07-16, 09:09 AM
N
picture isn't posting, but our neighbor is fixing it so I think all is well. Thank you all
Old 01-07-16, 09:29 AM
Got your image up for you just to satisfy everyone's curiosity.
G
Received 2 Votes on 2 Posts
Please let us know what the problem was and how it was fixed.
Usually the symptoms described lead to a broken torsion spring.
Old 01-07-16, 09:59 AM
Norm201's Avatar
Received 311 Votes on 280 Posts
Unless you have experience with garage doors I would not recommend DIY. Can't tell if this is a torsion spring or tension spring. If torsion, I strongly suggest you call in a pro. Saving money is one thing but your safety is another.
A pro will properly fix or replace that panel and make sure the door is properly balanced and securely attached to garage framing.
