Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Garages, Garage Door Openers, Work Shops & Sheds, Breezeways and Carports
Reload this Page >
Garage door opener sometime goes past up limit and become stuck on stop bolt.
Old 01-18-16, 09:51 AM
N
I have a craftsman garage door opener model # 139.53635srt. Sometimes when the door opens it goes past the up limit and hits the stop bolt - when that happens I have to release the tension in the chain and only then will it move again.
I am hoping this would a simple parts replacement but not sure where to begin. Here's a few pictures of the inside. Looks like the plastic nylon gears are grinding.
Thanks
Name:  Photo Jan 17, 4 42 10 PM.jpg
Size:  27.0 KBName:  Photo Jan 17, 4 42 49 PM.jpg
Size:  34.5 KBName:  Photo Jan 17, 4 43 03 PM.jpg
Size:  38.4 KBName:  Photo Jan 17, 4 43 36 PM.jpg
Size:  37.9 KBName:  Photo Jan 17, 4 43 47 PM.jpg
Old 01-18-16, 11:05 AM
Received 1,399 Votes on 1,296 Posts
Welcome to the forums.
Well... you're in luck. It is a simple parts replacement job. Those white shavings inside the unit are from the worn out drive gears. There is a rebuild kit available that comes with all the needed parts and an easy to follow instruction sheet.
The kit is from Liftmaster and is part #41C4220A
It's available from many sources.
LIFTMASTER-Openers-41C4220A-Sprocket-Assembly/dp/B006L8CZKI
Old 01-18-16, 02:53 PM
While I certainly agree that the gears are worn and need replacement I'm not sure how that would cause the problem that the OP is having. It seems like there must be another problem causing the overshooting of the limit switch. I wonder if possibly just the dust from the worn gears could be interfering with the encoder counting the rotations. Maybe until he gets a chance to replace the gears he could just blow out all that dust and see that some of the original problem.
Old 01-18-16, 03:55 PM
A
Received 72 Votes on 65 Posts
I can't say exactly how it correlates, and I know that my memory is failing, but I'm almost certain that the overtravel the OP described is what tipped me to look at my mom's opener. Mom's been gone quite a few years, and it was who knows how long before she passed, but it started doing something that prompted her to tell me about it, and I'm pretty sure that was it. (You know how mom's are, "I don't need a thing", then something quits working properly. Op, you may need to adjust the travel and/or force on it once you replace the gear, but no sense messing with it yet as you're obviously getting a lot of skip right now, and that gear alone may solve your problem. I'm thinking mom's was made by Emerson, might be wrong, but, as PJ said, they're available. It was most likely pre-internet, but I know I bought two at the time, because one was still hanging on a nail in a joist when we sold the house.
Old 01-20-16, 08:03 AM
N
Thanks for all the advice everyone. I ordered the replacement gear kit from Amazon and seen on youtube how the gears can be replaced. Looks pretty simple.
Anyways in my case since the gears are already worn and upon closer look, it seems that when the gears are not working in tandem the mechanism to trigger the stop is not actuated. So I'll try replacing these gears first and see how that goes.
Thanks!
Old 01-20-16, 12:33 PM
G
Received 2 Votes on 2 Posts
If you can gain access to the limit switch, clean the contacts with electrical contact cleaner or a piece of fine emery or sand paper. Over the years, the contacts build up oxidation and dirt and fail to make positive contact every time.
Old 01-20-16, 10:50 PM
During the rebuild it's very easy to see the travel limit contacts. If needed.... contact cleaner would be ok. I don't think I'd sand them.
The two red arrows are the fixed contacts and the blue is the movable contact plate.
During the rebuild process you will be taking apart the encoder. Be sure that's clean too.
Old 02-11-16, 05:15 PM
N
Just to update... a couple of weeks ago I replaced the gears from the kit and the surgery went well And it was fun too!!
When I took it apart I also cleaned out the RPM sensor; it was cover with the plastic shaving from the gears.
The problem has not shown up again. But I will still clean the contacts that you mentioned. Can I just use WD40 or alcohol? Or do I go out an get the official contact cleaner?
Thanks for the help and guidance.
Here is what is it looks like now:
Size:  40.0 KBName:  IMG_0341.jpg
Size:  35.6 KBName:  IMG_0339.jpg
Old 02-11-16, 05:28 PM
F
Received 36 Votes on 28 Posts
I would not recommend WD-40 as it will collect dust and it eventually turns gummy.
Old 02-13-16, 11:22 AM
D
Maybe not relevant in this case but this is common with Chamberlain OP's
Old 02-14-16, 07:04 AM
D
Cleaning the limit switch is often temporary. I would replace it.
It is the second most common part needed in these.
Just my $0.02.
Old 02-14-16, 09:59 AM
If the problem is gone..... don't do anything to the contacts.
